21 years agoNewbe in NIOS - so much questions
I'm starting now, I'm fresh new in this area, and I don't really know much ... I've tried to read what I have to do, but as I was reading, I have to go to other document, and then ...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Wich port I have to use to get the shell to comunicate with uClinux ? ByteBlaster II or MV ?[/b] --- Quote End --- By default the console appears on the JTAG UART. On our Cyclone board, this is the MV port. You can use nios2-terminal to access it. Alternatively you can configure the kernel to communicate on the serial port as suggested by marc. Dennis Scott Microtronix Datacom
