21 years agoNew version of NiosII Flash Programmer
Hello, I'm reading the manual for the Nios II Flash Programmer User Guide, but it appears to not cover my software? On page 18, figure 1-3 shows options for "Program flash memory with softwa...
21 years ago> From within quartus should I not be able to autodetect the FPGA
> and the Serial configuration device on the Jtag bus? > > I can only see the FPGA? You should only see the FPGA. The epcs is behind the FPGA from a JTAG point-of-view ... that's why the flash programmer design is necessary. > My only way of seeing/programming the Seial Configuration device is > thru the byteblaster header. If you don't have a flash programmer design, you are correct -- you would have to use the ASMI w/xxxBlaster. If you do have a (working) flash programmer design you can do everything through JTAG and avoid placing yet another header on your board. Joe, are you sure that your FPGA is properly loading its configuration from the epcs? You might want to program the epcs via ASMI and debug from there. Regards, --Scott
