21 years agoNew version of NiosII Flash Programmer
Hello, I'm reading the manual for the Nios II Flash Programmer User Guide, but it appears to not cover my software? On page 18, figure 1-3 shows options for "Program flash memory with softwa...
21 years ago> Unrecognized EPCS device ID: -1
-1 ... 0xff ? ... it might be time to pull out the scope to check your chip select, clock & data signals ... sounds like the data line could be stuck. Or you might want to try accessing the epcs device directly via asmi using xxxBlaster if you have a header available -- just to confirm your copper. If you're using u-boot, you can enable epcs support, download it via jtag & use the epcs commands to test. Regards, --Scott
