16 years ago
New type of error regarding altfb.c
I just wanted to recompile the uClinux kernel for my NEEK board and an error appears and interrupts the compiling process. I'm using the predefined systems files:
http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip, which should work fine.
/home/durb/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_dma_start':
/home/durb/nios2-linux/linux-2.6/drivers/video/altfb.c:225: error: `na_vga_controller_0' undeclared (first use in this function)
/home/durb/nios2-linux/linux-2.6/drivers/video/altfb.c:225: error: (Each undeclared identifier is reported only once
/home/durb/nios2-linux/linux-2.6/drivers/video/altfb.c:225: error: for each function it appears in.)
/home/durb/nios2-linux/linux-2.6/drivers/video/altfb.c:225: warning: initialization makes integer from pointer without a cast
Actually the driver altfb.c worked fine a month ago, but now after ./update the dist the error appears.
Could someone help me to solve this problem?
D.
1 Reply
    Never mind...my fault.
    Forgot to specify the development board.
