16 years agoNew to NIOS
Hello all, I am a moderately experienced fpga programmer but brand new to NIOS. So, I have used SOPC to generate a NIOS II and designated onchip memory to go with it. From Eclipse I have ...
16 years agoPlease allow me to give you a bit more detail because I've been there and still not sure how to proceed.
I'm using the Nios II/e along with jtag uart, sysid and onchip memory. My objective here is to write to the onchip memory a value that I can access and pinout to an LED on my cyclone III fpga. So 2 issues as I see it: 1) how do I actually write to the onchip memory from my nios II (i.e what is the syntax of a write and do i need some external libs) 2) once i write to the onchip memory, how do i actually access that memory from outside of my sopc project. How do I interface with the rest of my fpga?? Currently my nios system only has a reset and a clock port. How in the world am I to access the contents of memory of the onchip memory and then connect that to a pin on my fpga? nios_test_system_1 ( .clk_0 (clk40), .reset_n (1) );
