21 years agoNew Linux Kernel 1.4 installation
Dear Sirs: Could you, plase, tell me how install the new linux kernel 1.4 in the past, if i remember well there was an exe for installing everything. Thanks in advance Jorge Domingo AL...
21 years agowhoops... with regard to flash loading... it depends on how the board component for your development board is laid out. But the basic idea is:
(1) nios2-elf-objcopy -O binary vmlinux vmlinux.bin (2) bin2flash --input=vmlinux.bin --output=vmlinux.flash --base=0xXXXXXXXX --offset=0x0 (3) nios2-flash-programmer --sof=YYYY --input=vmlinux.flash --base=0xXXXXXXXX I'm doing a lot of this from the top of my head.... but that's the basic idea. 0xXXXXXXXX should be the base address of the flash component in your board component (i.e. altera_nios_dev_board_stratix_1s10 for a Stratix 1s10) YYYY represents the sof file within the component/system directory for the board component (i.e. altera_nios_dev_board_stratix_1s10/system/altera_nios_dev_board_stratix_1s10.sof) I can double check the commands later on... but it'll give you an idea of what's required.
