21 years agoNew Linux Kernel 1.4 installation
Dear Sirs: Could you, plase, tell me how install the new linux kernel 1.4 in the past, if i remember well there was an exe for installing everything. Thanks in advance Jorge Domingo AL...
21 years ago --- Quote Start --- originally posted by ranye@Jun 29 2005, 05:50 AM i would also be interested in in install directions for linux. i have
the toolkit for 5.0 installed in linux and i have been able to
use sopc builder etc. but i am not sure how to install
the 1.4 distribution under linux. --- Quote End --- I'm also working on Linux for this one (mainly commandline line) and my fears seem to be confirmed. From what I see, generating clean patches from this release is going to be the same pain as it was the previous time. I just hope they did not check in source files in CVS that they did not change; the keyword expansion pollutes the patch. /me fires up the patchutils I hope I can make patches available in the following days to go from linux-2.6.11 to linux-2.6.11-uc0 and then the microtronix changes. for the installation instructions, if you unzip the release, the directory structure look like Java logic, maybe it fits in the Eclipse directory structure. Otherwise, I there's an exe in the archive, maybe try it with wine. Anywho, you don't even need the eclipse stuff, just run it from the command line http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
