21 years agoNew Linux 1.4 installation problem
I recently installed Quartus II 5.0, NIOS II 5.0, and Linux 1.4. At the end of the Linux 1.4 installation I got the folllowing error message: "Cygwin extensions were not installed properly", "P...
21 years agoI'm having the same problem. When I run the install script, I get
umount: /usr/lib: No such file or directory Subsequent attempt yield a different error: No manual entry for umount I installed QuartusII 5.0 (reboot) Install Nios II 5.0 (reboot) Install Microtronix Nios II Linux (1.4) - this ends with an error about cygwin extensions not being install. (reboot) Run install_cyg_ext.sh (get errors above) I about to try uninstalling everything (again) and start over. Takes quite a while...
