21 years agoNew kernel release won't boot
Greetings. I was successfully configuring, building, uploading and booting the last release of uClinux on my hardware. I recently installed the newly released kernel and I'm back to the kernel n...
21 years agoHi thosburke,
Turn on MTD debugging at highest verbosity. Then check your partition map ... BTW: I don't see CONFIG_MTD_ALTERA in the (older) version I'm using. If your map is correct, it's time to take a look at your actual rootfs. Is your root romfs? Regards, --Scott
