21 years ago
New install uclinux1.4 error
After I install Q5.0, Nios 5.0, uclinux1.4, I open the Nios IDE, but I cannot find New uclinux project template in "new wizard"--only altera NIos II, C, CVS, simple
    Do you see the microtronix stuff under "altera/kits/nios2/bin/eclipse/plugins" ?
    rick
    Yes, I see:
    com.microtronix.nios2linux.application_1.4.0
    com.microtronix.nios2linux.common_1.4.0
    com.microtronix.nios2linux.filesystem_1.4.0
    com.microtronix.nios2linux.kernel_1.4.0
    com.microtronix.nios2linux.uClibc_1.4.0
    I fix it.
    I reinstall the Nios50 as full installation. Then the problem gone away.
    (First, I install the Nios5 without the "example of Verilog", but the Linux example should be in the "example of verilog" , so it is the reason.)
    When you installed Nios II 5.0, was the only thing you omitted the "verilog examples"? I'm just curious to see if I can duplicate the problem and fix it for the next release.
    Yes, it is.
    In another PC, the error turns out again. I found the Nios 5.0 is evaluation edition(with "verilog examples").
    After I uninstall it , and reinstall it, I install uclinux1.4 successfully.
    I think, maybe the error happens in the "setting " steps during installation. Some setting files or vairable is not available at that time.
    I had the same problem and fixed it by unstalling NIOS II and reinstalling selecting everything.
