New application creation failure in NIOS II - Quartus20.1
Hi Vinay!
Thanks for reaching us.
I see that Mviss4 has already provided you a workaround,
I'd like to know if you have tried and if this solved your issue.
and please, share with me the OS you're using ( Windows or ubuntu) and also the Quartus version.
-Eliath
I am using Quartus 20.1 in Windows 10 OS.
I have installed-uninstalled-reinstalled wsl and ubuntu multiple times, but to same result.
I have not tried the work-around provided, as it is confusing. How do I adapt a makefile, if the project itself is not getting created ?
Kindly provide proper procedure to follow for creating new projcet and building it.
Please donot leave tool debugging to the users.
Kindly provide step-by-step approach of new application creation, building and debug/run.
regards,
Vinay
PS : Due to project timelines, I am forced to revert back to Quartus version 14 where Nios SBT works without any issues. Debugging NIOS SBT is not my job domain(although I had spent many days making it work). I had tried installing Quartus 20.1 and building same project in two different computers and every time I am getting new errors.
