20 years agonet-snmp with Mircrotronix cross compile
Hi, with the Mircrotronix cross compile chain I'm trying to compile net-snmp 5.2.2. I get the following error when creating the libnetsnmp.so : /usr/local/nios2[long path]/3.4.3/[long path...
20 years agohi,
just download the latest net-snmp sources 5.2.2. edit config.sub: add "| nios2" in the "case $basic_machine in" run: ./configure --host=nios2-linux --with-cc=nios2-linux-gcc --disable-shared -enable-static --with-endianness=little compile and seems to work fine. (works under linux not cygwin) good luck, marc
