17 years agoNested interrupts again
Hello Linux masters, I need to make a small patch inside uClinux kernel for NIOS2. I need to enable one specific IRQ to have absolute priority over all atomic processes running in Linux - over ...
17 years ago<div class='quotetop'>QUOTE (jan @ Sep 9 2009, 12:40 PM) <{post_snapback}> (index.php?act=findpost&pid=23792)</div>
--- Quote Start --- the HDL component is blackbox[/b] --- Quote End --- Supposedly a management decision rather than a technical issue ? That is really not an adequate way of working with NIOS, as it dumps any benefit this system offers. If you can't work together with the "hardware" designers, there is no decent help for this project. But if you can add a second CPU in SOPC-Builder, using SOPC-Builder you also can add your own hardware component with an Avalon master interface that accesses the existing "black box" component via the bus (i.e. a kind of DMA controller). -Michael
