16 years agoNEEK Standard System with VGA Controller
Hello, I'm looking for NEEK Standard System configuration (EP3C25) (like: http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip) with a VGA Controller (like: http://forum.niosforum.com/...
16 years agoHi,
--- Quote Start --- Would this component (NEEK VGA TDM) http://www.alteraforum.com/forum/showthread.php?t=6118 work out for the encoding / multiplexing part? --- Quote End --- Yes, its file 'neek_rgb_vga.vhd' converts 30bits RGB data to encoded 10bits HC_VGA_DATA. I also recommend you to refer design examples with LCD and http://www.altera.co.jp/literature/hb/nios2/qts_qii55006.pdf . The conversion procedure is same. Also you can get the contents of EPM2210F324 in the NEEK's CD, directory 'maxII'. Kazu
