16 years agoNEEK Linux Tutorial
Hi All I'm new to Nios, but have been working with FPGA for some time now. Is there a tutorial or step by step for getting Linux with MMU up and running on NEEK? Including peripheral support ...
16 years agoHippo
I have downloaded neek_web_server_mmu.zip and took the custum_fpga.h from the archive and placed it in: ~/nios2-linux/linux-2.6/arch/nios2/include/asm with make menuconfig, changed to custom FPGA ran make with the resulting linux.initramfs.gz and cycloneIII_embedded_evaluation_kit_web_server.sof (renamed to neek.sof) from neek_web_server_mmu.zip I tried the steps below, but the LCD on the NEEK stays blank and nios2-terminal reports nothing Any ideas? [NiosII EDS]$ nios2-configure-sof /cygdrive/c/NEEK/neek.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;c:/NEEK/neek.sof Info: Using programming cable "USB-Blaster [USB-0]" Info: Started Programmer operation at Tue Nov 24 15:39:56 2009 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F30DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Tue Nov 24 15:39:58 2009 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 64 megabytes Info: Processing ended: Tue Nov 24 15:39:58 2009 Info: Elapsed time: 00:00:07 Info: Total CPU time (on all processors): 00:00:03 /cygdrive/c/altera/90/nios2eds/examples [NiosII EDS]$ nios2-download -g /cygdrive/c//NEEK/linux.initramfs.gz Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 3019KB in 52.1s (57.9KB/s) Verified OK Starting processor at address 0xC0000000 /cygdrive/c/altera/90/nios2eds/examples [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
