17 years agoNEEK example with ocm mmc_spi and mmu
Please find an example design of neek with opencore ethernet mac, mmc spi and mmu, at the wiki, http://www.nioswiki.com/linux http://www.nioswiki.com/@api/deki/files/345/=neek_ocm_spi_mmu...
17 years agoThis sounds GREAT !
I'll try to recreate the Binary Linux Distribution - with MMU - based on this ASAP (which will be not that soon right now :( ). Is there anything that might prevent booting this from the SD-Card with the Altera Application Loader (no u-boot) ? I suppose ALTUART without FIFO will not work decently. What prevents using the fifoed UART ? I suppose still no change signal for the SD-Card (AFAIU, this is a PCB design issue) ? How is the remote update going to work (e.g. FTP a new FPGA design file and/or Kernel Image (with embedded initramfs) What is the difference between ethoc and oeth ? I used oeth with NEEK-nommu and the latest versions of "hardware" and driver seemed to weor perfectly. -Michael
