20 years agoneed to explain .diff file
Hi hippo,
In max140apps.diff,like:Index: apps/ftpd/Makefile
--- apps/ftpd/Makefile (revision 1)
+++ apps/ftpd/Makefile (working copy)
@@ -2,20 +2,21 @@
# configurable options
# - set DEBUG = 1 to turn on debugging support
-DEBUG = 1
+DEBUG = 0
PROJ_NAME = ftpd
-INSTALL_DIR =
-PROGS := $(PROJ_NAME).exe
-CFLAGS +=
+INSTALL_DIR = ~/rootfs
+PROGS := $(PROJ_NAME)
+CFLAGS += -O2
PATHDEF_FTPLOGINMESG = -DPATH_FTPLOGINMESG=\"/etc/motd\"
PATHDEF_FTPUSERS = -DPATH_FTPUSERS=\"/etc/ftpusers\"
PATHDEF_FTPWELCOME = -DPATH_FTPWELCOME=\"/etc/ftpwelcome\"
+CROSS := nios2-linux-uclibc-
+CC := $(CROSS)gcc
# You should not need to modify anything beyond this point
-include Rules.mak
ifeq '$(DEBUG)' '1'
PROGS += $(PROGS:.exe=.gdb)
@@ -31,11 +32,12 @@
all: $(PROGS)
-$(PROJ_NAME).bin: $(FTPOBJS)
+$(PROJ_NAME): $(FTPOBJS)
+ $(CC) -elf2flt="$(FLTFLAGS)" -o $@ $(FTPOBJS) $(LDLIBS)
.PHONY: clean
clean:
- -rm -f *. *.elf *.gdb *.bin *.exe
+ -rm -f *. *.gdb $(PROJ_NAME)
.PHONY: install
install: all
@@ -43,5 +45,5 @@
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
- install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
+ install -v $(PROGS) $(INSTALL_DIR)/bin Does it generate by command diff? Could you explain it? Thank you??1 Reply
No, it is not created with diff.
I use subversion. svn diff see http://nioswiki.jot.com/versioncontrol (http://nioswiki.jot.com/versioncontrol)
