20 years agoNeed help fixing U-Boot for custom board- Nios2
nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)...
20 years agoHi shakthi,
I have never observed this problem, nor have I ever received notice that such a problem exists from any other Nios-II u-boot users. Have you solved this problem yet? And how did you generate your binary image? It looks like the type of problem that occurs when you use a custom tool that doesn't properly handle endian-order issues. Regardless, if it's a u-boot problem, I'd like to get it fixed -- please provide an update. Regards, --Scott
