13 years agoNeed help changing from Eclipse Console to HyperTerm or Putty
Hi, I have some SW running on NIOS II Stratix IV board on Eclipse. Now I want to use a standalone Hyper-Terminal or Putty. I did it once in Xilinx, but now HyperTerm is not available on Wi...
13 years agoAhhh... if you're using the jtag uart, then I believe you're stuck with using Altera's nios2-terminal/EDS, unless someone else knows a fancy trick.
--- Quote Start --- The JTAG UART core supports all Altera® device families. The JTAG UART core is supported by the Nios II hardware abstraction layer (HAL) system library. To view the character stream on the host PC, the JTAG UART core must be used in conjunction with the JTAG terminal software provided by Altera. Nios II processor users access the JTAG UART via the Nios II IDE or the nios2-terminal command-line utility. *http://www.altera.com.cn/literature/hb/nios2/n2cpu_nii51009.pdf --- Quote End ---
