13 years agoNeed help changing from Eclipse Console to HyperTerm or Putty
Hi, I have some SW running on NIOS II Stratix IV board on Eclipse. Now I want to use a standalone Hyper-Terminal or Putty. I did it once in Xilinx, but now HyperTerm is not available on Wi...
13 years agoOK, the NIOS2 design is using only a jtag uart and the dev.board has only one USB connector. The PC also has only USB connectors so how do I mate the Tera Term to the USB connector on the PC and from there to the USB on the dev. board?
Can the Tera Term be configured to communicate via USB? Thanks, S.
