13 years agoNeed help changing from Eclipse Console to HyperTerm or Putty
Hi, I have some SW running on NIOS II Stratix IV board on Eclipse. Now I want to use a standalone Hyper-Terminal or Putty. I did it once in Xilinx, but now HyperTerm is not available on Wi...
13 years agoIn regards to the nios, I've only used the jtag uart/nios2-terminal. If you have a standard uart peripheral, attached to an rs232 chip, it should work with any standard terminal program, like putty or teraterm. I've used both putty and teraterm with USB to serial converters without issue in the past to connect to various serial devices.
Cheers
