13 years agoNeed help changing from Eclipse Console to HyperTerm or Putty
Hi, I have some SW running on NIOS II Stratix IV board on Eclipse. Now I want to use a standalone Hyper-Terminal or Putty. I did it once in Xilinx, but now HyperTerm is not available on Wi...
13 years agoYou can change the stdin/stdout/stderr in the BSP Editor. Right click on your BSP, select "Nios II > BSP Editor...", Then you can select which device to send stdin/out to.
