21 years agoNeed Assistance
Hi, I am a FPGA designer(VHDL Coder) and we are planning on implementing a NIOS 2 processor into our VHDL designs. I took the NIOS 2 class which Altera was offering, the instructor wasn't very he...
21 years agoPatel,
Your question seems along the lines of "Where do I start?", in which case I'd ignore the advice to read about custom instructions until you have a better base of knowledge. I would recommend that you start by either reading the Nios II Software Developers Manual which can be found under your install in altera\kits\documents\n2sw_nii5v2.pdf, or alternatively if you start up the Nios II IDE under the help manual there are many tutorials.
