16 years agonano-x user program
Hello all, i tryed the nano-x, nanowm, nxview and i would like to write some user programs for nano-x windows. But when i wanted to compile the program from http://www.microwindows.org/programmi...
16 years ago --- Quote Start --- It reports: /home/uclinux/nios2-linux/toolchain-build/build/nios2/lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/bin/ld.real: cannot find -lphtread --- Quote End --- If you need a threadded application you can activate the pthread support in menuconfig and/or define your application in the config files to be depending not only on nano-x, but on pthreadlib, too. --- Quote Start --- Is any other way to draw/erase lines except use nano-x (lib) ? --- Quote End --- (nano-) X is the Linux way to use a graphical display. Everything else would be very non-standard and thus not supported by anybody.. --- Quote Start --- I tryed this links, but it doesnt exist: http://www.nioswiki.com/operatingsys...ux/framebuffer (http://www.nioswiki.com/operatingsystems/uclinux/framebuffer) --- Quote End --- No problem here. -Michael
