16 years agoNano-X issues
Hello, I'm running uClinux on the NEEK controlling an external touch screen display (Elo Touch) with Nano-X included in the kernel config. Everything works fine. I set Nano-X configuration...
16 years agoOf course the MMU enable full Linux system prevernts overriding of Kernel space by userland applications and thus is a lot safer. Moreover only the MMU enabled distribution decently supports threaded applications.
So if you have enough FPGA resources for the MMU and are not too tight with CPU performance, you maybe should convert. -Michael
