16 years agoNano-X issues
Hello, I'm running uClinux on the NEEK controlling an external touch screen display (Elo Touch) with Nano-X included in the kernel config. Everything works fine. I set Nano-X configuration...
16 years agoHi,
--- Quote Start --- i was not able to find some problems with the tslib. Actually the Nano-X application won't work anymore. Starting the Nano-X server is working fine. BUT when I start the NanoWM the systems freezes. --- Quote End --- How does it freeze? Normal 'ts_calibrate' for NEEK's touch panel will work well? If you feel any hardware malfunction, please try other 'Terasic' samples. Kazu
