16 years agoNano-X issues
Hello, I'm running uClinux on the NEEK controlling an external touch screen display (Elo Touch) with Nano-X included in the kernel config. Everything works fine. I set Nano-X configuration...
16 years agoHi,
i was not able to find some problems with the tslib. Actually the Nano-X application won't work anymore. Starting the Nano-X server is working fine. BUT when I start the NanoWM the systems freezes. I tested it with the following system design: http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip (thread: http://alteraforum.org/forum/showthread.php?p=79862) and the How-to-FrameBuffer of the NiosWiki. Did no changes to the design. Just tried to run Nano-X on the LCD of the NEEK. May it be some problems with the Nano-X application or even some broken hardware on the NEEK? Advices or ideas are appreciated. Cheers, D.
