11 years agoNAND flash booting problem
We made a custom board by using Cyclone5 SE device,as a booting option, provision is given for NAND flash only and there is no other boot option on the board. we are able to load the the preloader...
11 years agohello,
Am facing problem with u-boot loading from NAND Flash. As recommended am placing preloader image at 0x0 adress, and u-boot image at 0xC0000. Preloader is booting without any problem. But U-Boot is not running fully(on the hyper terminal, after 6 - 10 lines of u-boot nothing is coming). Its stopping in middle of the code. Each time at random timings its hanging. While the same code u-boot is working fine when i debug through DS-5. Once see the terminal window image, attached here. Pleae help me to solve the issue. Thank you in advance.
