22 years agoMy ukits doesn't work
I'm an embedded software guy who want to learn how to play with NiosII. I bought Microtronix's ukits last month.
After read Microtronix's documents in the CD named "Microtronix Nios II Linux Distribution Quick start Guide" and "ukits quick start guide", I follow the instruction include compile kernel, compile filesystem, upload kernel, upload filesystem, program the chip with linux.sof... etc. Finally, when I type nois2-terminal in the shell, I got the following message: [SOPC Builder]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0 nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: starting in terminal mode only (Control-C exits) Any body knows what wrong on it ? Do I need a USB Blaster revision B cable ? Thanks2 Replies
Is it just the warning message that you're concerned about? Or did the kernel not startup properly at all?
Ken, thanks for your reply,
Actually, My kernel did not startup properly at all.
