FENGE1
7 years agoMy problem is, that in the Run- and Debug-Configurations the "NiosII Hardware" Section is missing (under "Run As" / "Debug As"). Only the "Local C/C++ Application" can be selected.
Hi there, I am using Quartus 11.1sp2_259, and i also installed 11.1 SP2 Patch 2.11 for Windows in order to be able to use the USB-Blaster. My operating System is Windows 10. My problem is, that in ...
FENGE1
7 years agoI nevertheless finally resolved the issue by using the windows compatibility mode. For some reason this did not work when i did it manually, but when using the windows trouble-shooter, it worked fine:
https://www.laptopmag.com/articles/set-compatibility-mode-windows-10
