20 years agoMy PCB design for Cyclone II ep2c20F484;ep2c35F484
I am begginer ir FPGA and the problem I have is with these development bords is that they are very expensive! cheapest bord I found with cyclone II ep2c20 FPGA is firefly bord with cost 350$ and its ...
20 years agoHas anyone used POL power-off-load power supply tehnology????
I found bellnix BSV ultra fast series with switching freqency up to 3Mhz with low voltage ripple 40 mV and it needs only 2 22uF ceramic capacitors and few higher freqency caps and no inductor! Also I found 4Mhz power supply it is Ltc3414 (linear tehnology) ! I read about these high frequency switch power supplys and they are specialy recomended for FPGAs.
