20 years agoMy PCB design for Cyclone II ep2c20F484;ep2c35F484
I am begginer ir FPGA and the problem I have is with these development bords is that they are very expensive! cheapest bord I found with cyclone II ep2c20 FPGA is firefly bord with cost 350$ and its ...
20 years ago --- Quote Start --- originally posted by epis@Jul 30 2006, 05:36 PM now i decided to make 4layer pcb for ep2c20f256 ep2c8f256 and ep2c5f256 insted of 8layer pcb for ep2c20;35;50 in fbga484 package becose its to expensive and i dont now how big device i will need, so a good starting point would be ep2c20 in smaler fbga 256 package.
as i already have routed in 2 layers ep2c20f256 device then i will need to add ground planes and vcc int,i/o plane.
how much layers these small fpgas need 4 or 6 ?
if i will need in future larger device then i will make pcb for fbga672 package becose it covers larger devices than fbga484.
wen i will route mu nev 4 layer or 6 layer pcb the i will post link to pictures.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17265)
--- quote end ---
--- Quote End --- if you want a cheap board have a look at: http://www.jopdesign.com/cyclone/index.jsp (http://www.jopdesign.com/cyclone/index.jsp)
