21 years agoMy First Nios-II
Hi, I am trying to run a really simple Nios-II application using the ISS. After starting execution, the application does not even reach main(), however. Instead it decides to crash within...
21 years agoRoland,
The error message is complaining about the instruction fetch. <div class='quotetop'>QUOTE </div> --- Quote Start --- ERROR: [439] instruction fetch access to address 0x1af8 returned uninitialized memory[/b] --- Quote End --- It sounds like the simulator's memory at 0x1af8 hasn't been initialized. The simulator realizes this when it fetches an instruction from that address. <div class='quotetop'>QUOTE </div> --- Quote Start --- I wonder if it has to do with the remark 'valid mask=0x0' in the error message.[/b] --- Quote End --- I think that the value mask records which bytes of the memory have been initialized. 0x0 means an entirely uninitialized word. Kerry
