20 years agomy code won't execute after a CPU reset
Hi, I'm trying to do something very simple but since its failing, I think I'm not understanding something fundamental about the IDE's auto-placement of code into memory. I have tw...
16 years agoIn my case the ROM contains a separately compiled custom reset code that was overwritten by the debugger (EDS 9.1sp2) when downloading the program to the target (either for a Run or Debug session). Subsequently, the board did not boot anymore when the reset button was pressed.
Because I have pulled out half of my hair before I found out how to avoid it, I post here the steps to follow : - right-click on your bsp project and select "Nios II/BSP Editor..." - in tag Settings, select "Settings/Advanced/hal/linker" - uncheck "allow_code_at_reset" and "enable_alt_load" P9
