16 years agoMutex - uClinux (without mmu)
Hi I have a project thar includes 2 NIOS2 CPUs. Both need to access the same memory area in an SRAM. One of the CPUs runs software developed with the NIOS2 IDE, another runs uClinux. ...
16 years ago --- Quote Start --- Another question: my shared SRAM has base address = 0x04000000. Should I read/write it using base address = 0x84000000? --- Quote End --- If you want data to be immediately visible to another processor or peripheral, yes. I am pretty sure there are macros in uClinux that take care of this for you, check -- you might already be using them. (I am using the MMU version so can't check quickly myself). For Altera HAL, have a look at alt_remap_uncached and alt_dcache_flush.
