16 years agoMutex - uClinux (without mmu)
Hi I have a project thar includes 2 NIOS2 CPUs. Both need to access the same memory area in an SRAM. One of the CPUs runs software developed with the NIOS2 IDE, another runs uClinux. ...
16 years agoI might be off on this -- I'm not sure what the outl/inl macros do in uClinux, they might take care of this.
Without an MMU, the NIOS uses bit 31 to flag cached or uncached accesses. Since you have two processors accessing that memory, you have to set it to make sure the access is uncached. So you actually have to read/write 0x80000000
