16 years agoMultiprocessor on DE2-Board
https://www.alteraforum.com/forum/attachment.php?attachmentid=2891 Hi, I am having trouble in running multiprocessor project on DE2-board. I follow every steps in multiprocessor_tutorial an...
16 years agoHi Wangweike,
Do you mean u manage to run my attached nios.qar correctly? I have my jtag uart connected to the data master of cpu1 correctly, also I have verified jtag uart is set to stdout, stdin and stderr correctly. But somehow I still receive the output until this step: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) I expect there should be output such as Message from CPU 1. Number sent: 1 Message from CPU 1. Number sent: 2 Message from CPU 1. Number sent: 3 Message from CPU 1. Number sent: 4 But I can't get these output. Can u please help me? Thanks, Carid
