20 years agomultiprocess and flash programming?
Hi, I write a simple program for including two nios in one design and i try to write some S.W. for each processor. I have already tested but i don't know how to use flash programming to...
20 years agoHi
even i feel the same thing? even if u implement all the boot codes in sdram with different base addresses it may not be possible for them to boot parallely as they have only one data bus(32-bit) hence i think avalon bus arbiter will play a major role in arbiting the sequence of operations. regards prasad
