20 years agoMultiple USB Blasters on the same PC
The problem is that Altera provides each device with the same serial number. This should be no problem unless one wants to connect several USB Blaster devices to the same computer. A new serial...
20 years agostonie: This file for UsbBlaster RevA!!!
In MProg utility run read(not read and parce). And see string at offset 0x4e! With this string UsbBlaster identified as revb and others. This string is revision.
