20 years agoMultiple USB Blasters on the same PC
The problem is that Altera provides each device with the same serial number. This should be no problem unless one wants to connect several USB Blaster devices to the same computer. A new serial...
20 years agohere is the MPROG .ept file i got from the USB Blaster Rev C EEPROM:
[Basic Details] Device Type=3 VID PID Type=2 USB VID=09FB USB PID=6001 [USB Power Options] Bus Powered=1 Self Powered=0 Max Bus Power=150 [USB Serial Number Control] Prefix=91 Use Fixed Serial Number=0 Fixed Serial Number=91d28408 [USB Remote WakeUp] Enable Remote WakeUp=0 [Windows Plug and Play] Enable Plug and Play=0 [USB String Descriptors] Manufacturer=Altera Product=USB-Blaster [Programming Options] Only Program Blank Devices=0 [BM Device Specific Options] USB Version Number=0 Disable Serial Number=0 IO Pin Pull Down in Suspend=1 [Dual Device Specific Options A] RS 232 mode=1 245 FIFO mode=0 245 CPU FIFO mode=0 OPTO Isolate mode=1 High Current Drive=0 [Dual Device Specific Options B] RS 232 mode=1 245 FIFO mode=0 245 CPU FIFO mode=0 OPTO Isolate mode=0 High Current Drive=0 [Dual Device Driver Options A] Virtual Com Port Driver=1 D2XX Driver=0 [Dual Device Driver Options B] Virtual Com Port Driver=1 D2XX Driver=0 hope this helps... Klaus
