20 years agoMultiple USB Blasters on the same PC
The problem is that Altera provides each device with the same serial number. This should be no problem unless one wants to connect several USB Blaster devices to the same computer. A new serial...
20 years agoWell that's a timely post. Can you post the template file for programming the blaster, ie what you uploaded from it using mprog?
I have an FTDI device on a board that I was programmng, but at the same time had left the usb-blaster plugged in. Guess what - mprog programmed the wrong device and I now have a non-functioning blaster. There's a lesson there somewhere.
