17 years agoMultiple Triple Speed Ethernet with microOS II and interniche
Anybody can tell me how to set the driver to handle multiple TSE in the Nios II software?
I have Nios II EDS 9.0 sp2, running microOS II with interniche.. As soon as I have 2 TSE Ethernet defined, my system crashed upon execution or when any data coming from the ethernet. Anybody can help? Best, E14 Replies
i have done this before without error, this may be some specific configuration issue.
--dalon - Altera_Forum
Did you remember if you need to set any parameters or definition to have run?
According to Interniche, we only need to enable the MULTI_HOMED and IP_ROUTING definition. Appreciate if you can help.. Best, - Altera_Forum
did not have to do anything. I made one minor modification to the driver to allow me to easily determine which TSE was which, but that is it.
Are these 2 entirely separate TSEs with independent SGDMA's or a shared FIFO implementation? --dalon - Altera_Forum
Either way, it gave me the same problem.. What setting you did?
I found that tse_mac_device structure array of 4, was only filled with 1 TSE structure address, which is the second ethernet. The first ethernet were never initialized.. So when it received message, it ran an invalid instruction (wildcard instruction).
