13 years agoMultiple SOPC files in a NIOS project
Hi, I have two different boards with different FPGAs (but pin-pin compatible). I know that I need two different quartus projects, but do I also need two different nios ii projects? The only thi...
13 years agoAlso take a look at the scripts I created with the files linked to in this thread:
http://www.alteraforum.com/forum/showthread.php?t=35678 The appendix of the document tells you how to start Quartus so that the Tcl console has the path to executables correct, allowing you to have the Tcl script re-generate the Qsys/SOPC system. Cheers, Dave
