21 years agoMultiple serial port misbehavior
Quartus 4.1, Nios1.01: The NiosII system has 2 uarts, a primary debug terminal@115K baud, and a secondary half-duplex slave [email protected] baud. During operation lots of printf output (from ...
21 years agoAre you using (or needing to use) hardware handshake? Does the UART indicate Rx overrun? If the device is talking to a PC, make sure the Tx FIFO is set to 1.
