19 years agoMultiple PLL clock error
Anyone that has any insight to this please help! Thanks! My set-up is I am trying to make a project using the VGA of my DE1 Altera Development board as well as the SDRAM. In SOPC Builder:...
19 years ago --- Quote Start --- originally posted by zippyua@Mar 1 2007, 05:04 PM anyone that has any insight to this please help! thanks!
my set-up is i am trying to make a project using the vga of my de1 altera development board as well as the sdram.
in sopc builder:
i am using the deboards external interface and i have the boxes selected to create a clock signal for sdram as well as vga.
i am using altera's university program vga ip.
my clock signals are as follows:
clk - external - 50 mhz
dram_int_clk - external - 50 mhz
vga_int_clk - vga<-de_board - 25 mhz
note: i tried the design two ways the latest is as stated above. the other is i tried it without the "dram_int_clk" clock at all thinking maybe the external interface would just take care of it all. my choices for clock source for the dram_int_clk are 'external' 'vga<-de_board' and a blank choice. it would make perfect sense and really seems like there should be a 'dram<-de_board' option since it seems like thats created by the external interface. but this option does not exist.
current quartus set-up:
in the block diagram i have the clock output signal created by the system for the dram wired back around to the 'dram_int_clk' input pin to the block diagram. there is the boards 50mhz clock pin assigned to the input pin to the clk signal input. there is an output for the vga_int_clk signal but i am currently not doing anything with that signal.
when i compile:
sythesis completes
fitter fails and i get the message "input clock "clk" cannot feed more than one pll"
i am confused most by this because i am not directly assigning the clock signal 'clk' to anymore than one pin. i've read that you can manually combine clock generation signals into one pll but i have no idea how to go about doing that. and if i do do it will the clock signals maintain their present phase shifts?
again, any insight from anybody will be greatly appreciated! thanks everyone!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21948)
--- quote end ---
--- Quote End ---
