16 years agoMultiple Ethernet application under MicroC/OS-II
Hi, there I am a new one for the MicroC/OS II system. Now I am working on the multiple Ethernet application based on the NicheStack and MicroC/OS II. Can anyone provide some reference design a...
16 years agoYou don't need a separate DDR: all dma share the same memory. My system is the same as yours: 2 tse, 4 dma a single dram; the only difference being I'm using sdram controller, not ddr.
I can't tell you what that error is due to. Try check in sopc builder: - connections between dma and ddr - interrupts, arbitration,base addresses - ddr module configuration Then in Quartus, if you use top level schematic, check if any connection is missing or if a couple of them has been wrongly connected together. About socket programming. One ip address for each Ethernet port (you must define the get_ip_addr() function which will be called by interniche upon initialization) One socket for each tcp/udp connection you need. The tcp/ip stack will take care to move data to and from the correct physical Ethernet port.
