20 years agomultiple definition of `_start'
Hello members of the forum... I am new working with Nios and programming applications C/C++ for that reason I please need the aid an expert who knows, wants and can help me to solve the errors of my small application of test,
The application:# include <stdio.h> int main(void){ printf("\nThis is a test of the application CPP2...bye\n"); return 0; } The error: make -k all no emulation specific options. nios2-elf-gcc -msys-crt0="c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/crt0.o -r -d -L"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o cpp2.bin cpp2.o /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a cpp2.o(.text+0x0): in function `_start':: multiple definition of `_start' c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/lib/crt0.o(.text+0x0): first defined here collect2: ld returned 1 exit status make: *** [cpp2.bin] Error 1 make: Target `all' not remade because of errors. I will thank for the aid of an expert who has knowledge about how to solve this problem.
Thanks, I tried out your elf2flt_ld script. I didn't patch it. Now the linker is getting some undefined references....
I didn't try to execute it, 'cos it would probably crash anyway. Any thoughts?nios2-linux-uclibc-g++ hello.cpp -o hello -elf2flt="-s 64000" hello.elf2flt(.text+0xc964): In function `__uClibc_fini': : undefined reference to `__fini_array_start' hello.elf2flt(.text+0xc968): In function `__uClibc_fini': : undefined reference to `__fini_array_start' hello.elf2flt(.text+0xc96c): In function `__uClibc_fini': : undefined reference to `__fini_array_end' - Altera_Forum
There are two versions of uClibc that we are talking about.
20060207 or 20060208, the older one, use the elf2flt.ld from elf2flt_ld.zip. 20060214 or later, the newer one with fini_array, use the patches which I post to busybox. But both will crash on libstdc++. I made the patches from normal elf ldscript. Maybe you can try to trace it out. - Altera_Forum
OK, I got confused by this. I will try to trace it.
