20 years agomultiple definition of `_start'
Hello members of the forum... I am new working with Nios and programming applications C/C++ for that reason I please need the aid an expert who knows, wants and can help me to solve the errors of my ...
20 years agoHi carol,
It is the startup crt0.o problem. It should be easier if you work on Linux and follow my buildroot guide, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) The step8 in port#1 tells you how to compile and run a simple program on uClinux. About C++, you can not use nios2-elf's libstdc++, it is bond to newlib. On uClinux, you should need that which is bond to uClibc. The libstdc++ which we built with uClibc still have problems, it compiled and linked, but crashed when running on uClinux. I am not a C++ user, and I can't resolve the problems without help from C++ user.
