20 years agoMultiple CPU or Nios II?
I'm working on a project that requires data to be read into a NIOS out of on chip FIFO. The data is then processed and stored onto a CF card. My problem is that their doesn't seem to b...
20 years agoThanks for the ideas guys.
Right now though I am looking into my first idea of increasing the speed of writing to the CF card. I went into the PTF file for the CF interface to adjust the timing for the card and changed Read_Wait_States = "530ns";
Write_Wait_States = "500ns";
Setup_Time = "70ns";
Hold_Time = "30ns"; to Read_Wait_States = "140ns";
Write_Wait_States = "120ns";
Setup_Time = "30ns";
Hold_Time = "10ns"; and saw very little difference in write speed to the Flash Card (SLCF2GBJI). the speed was approximately 800kb/s. Then for completeness of testing I slipped in a sandisk CF card (SDCFBI-2048-201-80) and ran the same test. I received drastically better speeds of approximately 1.8 MB/s. I rechecked my numbers, reran the tests, and had 2 other engineers verify my results and methods. I checked the data sheets in which both say they can preform in mode 4 and the timings that are given in the data sheets are exactly the same as those in the CF.org specifications ver 3.0. My first question is how do I convert "cycle time" and "-IORD/-IOWR" timing etc from the spec to the "Read_Wait_States" etc of the ptf file in nios My second question is why would I be getting such different answers for two supposedly identical cards? Thank you for your time Steve
