21 years agoMultiple Clocks to on board compoents
I am working on a design (on the Stratix Professional Board) that utilizes the on-board SDRAM and the Lancelot VGA DAC I attached on. Currently, the design is configured at 50Mhz. The SDRAM (U57) mus...
21 years ago --- Quote Start --- originally posted by camelot@Feb 5 2005, 06:25 AM you should to change video_clk into pll to 25 mhz, but not clk of dac. --- Quote End --- It needs change both the vdeio_clk to 25.175Mhz and the PCB design of Lancelot board. In the Lancelot board, you must cut-off 1-2 connection of J1, connect 2-3 of J1, and add a 25.175Mhz OSC to X1. Of couse the related registers of Lancelot board must be also changed to match 640*480 mode. Now, because the clk for video DAC is from 25.175MHz OSC of Lancelot board, not from buffered clk from PIN_E15, you can maintain the PIN_E15 to 50 MHz to SDRAM devices and CPU. Hope this is helpful. -- Kaku
